XJ2025H maintennce ? help
   / XJ2025H maintennce ? help #1
cvcman
syracuse ny
john deere
Ok at 40 hrs I did the 50hr service..chgd the 3 filters, engine oil,,,,now I never changed the fuel filter or air filter...the maintenance schedule someone posted here said like 250 hrs for the air fiter and 500 hrs for the fuel filter....is this right ??
   / XJ2025H maintennce ? help #2
You should have the Maintenance Schedule in your Owners Manual. My 3135 just says to check at 50 Hours. I would check for water in the fuel filter though.
   / XJ2025H maintennce ? help #3
You're Ok. Just periodically remove the air filter element and carefully blow across it for now. The manual will spec 50 for cleaning the AF and the hours that you specified to replace. That being said, have replacements on hand should you need it. Especially the fuel filter.
Mini Forks (A50322)
Mini Forks (A50322)
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2006 Cat 963C Crawler Loader (RIDE AND DRIVE) (NICE) (A50774)
2006 Cat 963C...
2023 CATERPILLAR 299D3 XE SKID STEER (A51242)
2023 CATERPILLAR...
UNUSED KIVEL HANG ON WHEEL LOADER PALLET FORKS (A51244)
UNUSED KIVEL HANG...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
