X744 Wheel Spacer Kit
   / X744 Wheel Spacer Kit #1
Gonerafting
Elk,WA
x744
The John Deere Accessories Catalog lists wheel spacer BM22725 as necessary on the X729 and the X749. I assume it is an oversight that it does not list this as necessary on all four wheel steer tractors to clear the rear tie rods when installing chains. Am I correct in needing the wheel spacer on my X744 when installing chains? Thanks, Jim
   / X744 Wheel Spacer Kit #2
I don't think you need them. The X729/X749 have 26x12-12 rear tires and the X724/X744 have 26x10.5-12 rear tires so you should be ok.
Thank you for the response! I thought also the big difference in clearances maybe the larger tire size on the X729 and X749.
   / X744 Wheel Spacer Kit #4
Give you local JD dealer a call to find out for sure.
I was at the Dealers today buying 54 inch snowplow, chains, weights. The Wheel Spacers are not necessary on the X744.
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
1991 International 4900 Box Truck (A51039)
1991 International...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
AFE SSMM Disc Mulcher Skid Steer Attachment (A49461)
AFE SSMM Disc...
