X744 600 hour report
   / X744 600 hour report #1
unit40
Massachusetts
John Deere 1070
My 2007 tractor just turned 600 hours. I did a complete service, washed and waxed it, got it ready for spring. Very pleased with the tractor so far and thought I would share the good and the bad, after all it has been 5 years with this awesome machine.
The bad....radiator leaks. Had to remove it and bring to a repair shop. Plastic aluminum radiators are cheaply built. Deere wants $300 for a new one, cost me $95 to have it tuned up. Repair shop re-crimped and had to repair one corner so they worked on all 4 corners of the tubes. So far so good.
One day found a puddle of hydro on the garage floor under the tranny. Saw it dripping. Then it just stopped. The tractor had been sitting for quite a while. Thought it came out the vent because I checked the fluid level and it was really high. Don't know how that could happen, but after I serviced the machine and ran it all day spreading fert and tick control no more leak at all.
Seat frame got rusty. Had to disassemble, clean-up and repaint.
Fuel gauge lies. It works, but if it lies to me then I guess it doesn't really work.
The good....just about everything. After the ice storm a couple of years ago I purchased a 10K PTO generator which I can plug into the house. We lost power several times for many days since then. The tractor will run all day, non-stop, providing power.
I purchased the 744 new with a block heater, lockout valve, 62C with 14 bushel powerflow, rear PTO and 3pt hitch. Since then I have added a Edson sportsman powerknob, a transaxle hydrorelief valve, Gator G6 (I think) magnum high lift fusion blades, removed all deck covers, disabled the reverse mower shut off RIO, a Landpride PTO spreader, PTO generator, PTO chipper, Johnny bucket Sr, with a tooth bar, some vbar tire chains. The machine has proved to be extremely versatile, extremely comfortable, and extremely maneuverable for mowing, landscaping work, or clearing snow. I treat the fuel with powerservice additive, and use Rotella synthetic 5/40 oil. Even drained the gearbox on the deck and filled with synthetic gear oil.
I found that the mowing and handling capabilities of this tractor to be superior
to many other machines I use that I purchased under Gov't contract a x749 for my Municipality. We need the 4wd/4ws capabilities for some very challenging areas we maintain and the guys absolutely love it. It will do a better job than our JD997 or our front-mowers in most situations, especially steep terrain.
So today, at 600 hours, my X744 looks and runs like a brand new machine fresh off the lot. Although primarily used for mowing an acre of fine turf and another 3 acres of selectively cleared wooded grassland (if that makes sennse) this machine has definitely proved it's value. I think I'll keep it.
   / X744 600 hour report #2
Thanks for the informative write up.:thumbsup:
I have found many uses for the x749 with 3PH and rear pto too.
   / X744 600 hour report #3
The X744 is an Awsome Mower! I also have a 2007 Deere X744 AWS with 48" deck. I picked it up used in 2010 with 692 hrs on it. As of Saturday, it now has 888.2 hrs on it, and has been a great mower! The AWS really shines for manuvering into tight corners and mowing smaller lawns that I used to have to use a 38" deck on.
Very fuel efficant mower too, and will definately be kleeping my X744 Deere for a long time yet.
Jason B
I forgot to mention that I had installed the anti-blowout leaf bagging kit on the deck but eventually took it off. It creates some voids within the deck that accumulate grass that eventually start to rot away. Those voids are near impossible to clean out and will cause the deck to rot out if not cleaned out.
2015 CATERPILLAR D6K2 XL CRAWLER DOZER (A51242)
2015 CATERPILLAR...
PALLET OF MISC HOSES (A51244)
PALLET OF MISC...
30' Harvest Hand Head Cart (A50514)
30' Harvest Hand...
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
2019 CATERPILLAR D6 LGP HI TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
