X739 48" Mower deck under side paint quality
   / X739 48" Mower deck under side paint quality #1
bgWI
West central edge of WI along the Mississippi Rive
Kubota GL4330
A year ago I purchased the X739 with the 48" deck. Our yard is an obstacle course of trees, walls and undulating terrain. Too much for a 54" deck width. Our 425 AWS with a 48" deck served us faithfully for many years. My point of interest /concern is the under deck paint quality or lack of such. I hot water pressure wash the deck out every 3rd use or so if mowing in dry conditions. I use the 2-bag pickup system. Today I spent a long time washing the accumulation of dirt and grass off the unit. It seems the surface is very rough, making it difficult to clean efficiently. Also, rust is forming on the underside of the deck outlining the exterior weldments of the wheels and other attachments on the top of the deck. A poor paint job at best.
Has anyone recoated the underside of their decks with paint or other product to facilitate keeping the deck clean and rust free for a long life of use?
   / X739 48" Mower deck under side paint quality #2
Keeping the underside dry is the best way to keep it rust free, IMO.
I avoid washing the deck if at all possible... maybe twice a season. Mine is shiny steel... no rust.
   / X739 48" Mower deck under side paint quality #3
I'm in the no water camp also, water and steel equals rust. I only use an air hose to blow the dust, dirt and grass clippings off the tractor and mower deck. Then once a year I'll remove the deck and scrape the green crud build up off the bottom. Have never washed a tractor or mower in my life and so far have never had a deck rust through, my JD318 steel deck is 27 years old and still hole free.
I also would never use a pressure washer on anything with bearings or seals, seems like a good way to force water and crud past the seals and into the bearings.
   / X739 48" Mower deck under side paint quality #4
Eric
:thumbsup:
   / X739 48" Mower deck under side paint quality #5
Honestly, I think you are hampering your efforts by washing it that often. Washing simply introduces moisture to the underside of the deck. Rust is like cancer. You cannot just cover it, or take off the surface rust. It will simply rot through from the other side.
Personally, I only power wash my deck once a year, in the fall right before winter storage. I power wash my deck, then I proceed to paint it, but, I paint it by hand. Go down to your local JD dealer, you can buy JD paint, green, yellow and black, in cans. When you paint the underside of the deck with a brush, you can get a much thicker coat, plus no overspray.
Manufacturers are getting cheaper and cheaper. They want less production costs with more profit. The way JD looks at it is why bother to put a first class paint job on the underside, when it will simply be worn off anyways? Also, in today's world, all manufacturers that spray parts have to pay for it. It's like vehicle production. Every time a car is painted, the company has to pay for the damage that does to the environment. JD has to pay that too. So the more paint they use, the more it costs in product, and in fees.
Honestly, just make sure you have one really good thick coat of paint on in the beginning of the season, and go with that. Throughout the season, clean the underside out with a plastic putty knife. After you paint, you can put a coat of fluid film on if you wish. It's more or less a clear liquid wax in a spray can. Don't apply too much, and you must wipe it down after it has cured for 10 or 20 minutes. This will get off the residue and leave you with a slippery surface.
   / X739 48" Mower deck under side paint quality #6
I'm also in the no water camp. I used a 425 with a 54" deck for 19+ years (1165 hours). It only saw one bath: right before I sold it. Mower deck was still very solid and original paint on the outside was like new. There was surface rust underneath, but because it was dry 99% of the time, it never seemed to grow any. I scraped it off sometimes at the end of the season, but mostly did nothing. I don't know why JD encourages washing with the hose port they put on the new decks. I know I won't be using it.
   / X739 48" Mower deck under side paint quality #7
I use my backpack blower to clean off the mower when needed. I scrape off the underside of the deck when changing blades. I do have a big pressure washer but don't use it on my equipment for any routine cleaning, as other stated you can do more harm than good.
I am sure that some people feel that they are taking better care of their mower if they keep it super clean but in reality some of this over cleaning is more detrimental than leaving the thing alone.
   / X739 48" Mower deck under side paint quality #8
Agree....no water.
   / X739 48" Mower deck under side paint quality #9
When I was a little kid I watched the neighbor wash the underside of his push mower in the alley between our houses. When he was done, I remember he was a mess and the alley was a mess for a couple days until it all dried up.
I have never washed the underside of a deck and most likely never will.
   / X739 48" Mower deck under side paint quality #10
I only scrape any clumps or build-up in the corners then mow DRY grass to keep it clean.
2022 Weber MT CF2A Plate Compactor (A55851)
2022 Weber MT CF2A...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2007 MACK CTP (GRANITE) ROLLOFF (A56129)
2007 MACK CTP...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
John Dozer JD650 (A51691)
John Dozer JD650...
