X730 Fuel consumption?
   / X730 Fuel consumption? #1
tjr9183
Leipsic, Ohio
deere x730
I just bought a new Deere X730. I'm not sure if I'm getting the right fuel consumption out of it. I read the reviews on it and everyone says great fuel consumption. That's why I have to question with mine. I use a full tank in 2.4 hours. That's half a tank everytime I mow. I could mow with quarter tank with my 425. The dealer doesn't know if that's good or bad, so I'm looking for a answer from someone who has one.
   / X730 Fuel consumption? #2
I have a 425 and had a 445 (Electronic fuel injection) and also now have the X485 with EFI.
Both the EFI's suck up more fuel than the 425 IMO doing the same work (54" mower decks).
One big reason I enjoy the 455 diesel.. goes forever on a tank of fuel.
Now you just need to interpret what "great" fuel consumption means... those selling fuel think it is "great". :D
:welcome: to TBN
   / X730 Fuel consumption? #3
I have an X720 which is essentially the same thing. Love the Kawi motor, but they drink the gas. It's normal.
   / X730 Fuel consumption? #4
Yep, my X739 is about the same. Cost of doing business with the big X7's.
   / X730 Fuel consumption? #5
If I use the X739 it takes about 2.5 hours to fully mow property of approx 2 acres. Not quite a full tank, but certainly getting near the red. Tank is listed as 5.2G. Seems close to your experience.
Empirically, the JD seems to use more fuel than previous Craftsman (25 HP B&S).
In my case I wanted the AWD / AWS and the X749 was not available anymore & didn't find any good used ones. Unless used in a commercial setting it seems to me except for bragging rights, the extra cost for diesel ($1,200) would never be recovered in fuel cost savings.
   / X730 Fuel consumption? #6
I have an X734, and it replaced a 425 AWS.......same results for me.....the X definitely uses more gas, but I went from 18 HP to 25 HP, and from 54" deck, to a 60" deck......love my X734!!!! Fadz
   / X730 Fuel consumption? #7
Got a 2013 X750 with 60" HC deck. It comes standard with the 40amp alternator. A $500 option on the X730 gas mower. It also states on the top of the engine's valve cover 19Kw, which equal out to 25.5hp approximately. Don't know if this is a misprint, or I got one of the last 19Kw engines by happenstance. I use Mobil 1 full synthetic in the engine, Amsoil severe gear 85-90w in the deck gear box, changed twice already, and grease deck with full synthetic on the deck spindles. The last diesel fuel I bought for it was $2.39 off road. Now that it has about 136 hours on it, the fuel consumption has improved greatly, almost astonishingly. I always run at WOT for mowing. Put about 50 hours a year on it. So the additional $500 for diesel for me was a no brainer. Plus it is a 3 cylinder engine, diesels are good for about 120 degrees power output of rotation on the power stroke, verse 90 degrees on a gas motor. Three cylinders means that it almost always have a power stroke pushing torque to the drive trains, both motion for the machine, and deck drive. The thing is a tank of a machine for mowing. I went over to my neighbors to test if John Deere was truthful with their advertisment. I mower through heavy thick grass over 18 inches tall, and mostly about 2 foot tall. The mower maybe dropped about 50rpm. It is an absolute beast, and turns on a dime. I let one of my boys mow with it, asked him how he like it. He said it drove better than his car and wanted to drive it home to his house. I have also changed the low-vis fluid and filter with JD low-vis as recommended. You can smell the EP additive, and smells like some of the fully synthetic trans fluids I have used in the past. I suspect it is a full synthetic from JD, maybe a 0-20w. I understand it may be made by Chevron for JD. I got it from the dealer for about $70 5 gal pail.
   / X730 Fuel consumption? #8
I have a X740 diesel w/62" deck and uses between 3-4 gallons for 7.5 acres running wide open at 5.5 hours or so. I got a JD 3750 w/ 84" deck so I can minimize the time. My wife drives the 740 and I drive the bigger tractor and even though fuel consumption went way up mowing that way I don't bother checking it anymore.
   / X730 Fuel consumption? #9
Yep, that's normal for my X739 also. A small price to pay though for not having to breath in diesel fumes:)
   / X730 Fuel consumption? #10
Love them diesel fumes from my X740
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Year: 2021 Make: Chevrolet Model: 3500/4500 Vehicle Type: Truck Mileage: Plate: Body Type: Tilt Cab (A51692)
Year: 2021 Make...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
BOX OF SCHUMACHER1.5A BATTERY CHARGERS (A51248)
BOX OF...
