I have been reading about why hydraulic pumps are noisy when the fluid is cold. I read about higher viscosity of cold fluid and cavitation often due to a clogged filter or other obstruction in the intake hoses causes the pump to draw air.
My tractor has ~450 hours on it and runs great. I have changed the hydro oil and filter once in the recent past. I used the correct Deere low viscosity hydr oil and only recently has the pump gotten really noisy when cold. The fluid is full and the noise goes away when the engine and fluids warm up.
I plan to change the fluid filter just for good measure and to see if it helps but I have a question for the group..... does the deere X728 have a hydraulic sump screen in addition to the screw-on fluid filter? My local dealer tells me that it does but I can't find it in my technical service manual. I was told that I would need to remove the left rear wheel to access and clean it.
Mike.
Mike.
