X728 Air Cleaner Slotted Washer
   / X728 Air Cleaner Slotted Washer #1
Doxiegals
Chaska, Mn.
John Deer X728
I must have forgot to re-install the "slotted washer" that goes under the knob for the air cleaner on my X728 and cannot find it. Without it the knob will not tighten the cover all the way. Do you think I could just add a regular washer or two to make up the difference? (I believe the knob is running out of threads) This washer has something to do with covering some holes on the air cleaner.
I believe the part number for the washer is #M147404.
I'm a tight wad, they want like $30.00 to $40.00
   / X728 Air Cleaner Slotted Washer #2
Add a small outside diam washer that doesn't cover the holes.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
2017 HINO BOX TRUCK (A53426)
2017 HINO BOX...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
