X700 series tire size
/ X700 series tire size #1
couch-man
The X734/54 have narrower tires than the rest of the X700 series including the X739 which is also AWS and has the wider tires. Does anyone know why? Can the wider tires be put on the X734/54?
/ X700 series tire size #2
Never noticed this before. My x749 4x4ws has the 26 12 12 tires as does the x700 2wd 2ws. I had thought all of these used the 26 12 12 tires and wheels. The front tires have smaller rims on the x734 too, 8" diameter vs. 10" on the x749.
If you are shopping I would recommend going with a model with the 26 12 12 rears and 18 8.50 10 fronts.
Don't know why but maybe clearance issues with the mower decks?
/ X700 series tire size #3
It is because of a clearance issue on the 2 wheel drive all wheel steer tractors. They have a shorter wheel base than the 4x4 all wheel steer tractors.
Thank you, I've been to a couple JD dealers where the L&G salesmen didn't have the answer.
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2000 Sterling L9513 Winch Truck (A61306)
2000 Sterling...
78in Dual Cylinder Hydraulic Brush Grapple Skid Steer Attachment (A59228)
78in Dual Cylinder...
2007 Ford E350 (A55973)
2007 Ford E350...
