X595 no power to glow plugs
   / X595 no power to glow plugs #1
JdmansX595
Tried starting my tractor and.... Nothing
I checked voltage at the glow plugs and I have no voltage. I think I have a bad glow plug relay.
Is there somebody that can tell me where the glow plug relay is located and how to test it to see if it's bad?
   / X595 no power to glow plugs #2
I replied to your PM but just on the off chance it might be helpful to someone else in the future I'll repost this here:
Hi, the lack of power at your glow plugs could be a bad relay or a bad Diesel Control Module. I don't recall off hand which relay controls the glow plugs but they are so easy to test you might as well just test all three. The relays are right under the circuit board mounted to the chassis upright. If those all test good then you probably need to get a new DCM. To test the relays you can disconnect them and apply battery voltage across the coil terminals (at this point you should hear it click), then check for continuity across the load terminals (should be very low ohms - maybe 3-5 maximum). If the relays test good you probably need part #TCA12346 (DCM) which is the little white box located on the opposite side chassis upright that has a 6-wire harness/plug. I don't know of any tests for this part other than the glow plugs not working (no voltage being supplied to them) and the relays being good.
Found the problem, there was a bad wire connection at the plug for the glow plug relay.
Glad it was a simple fix!
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2005 Wilson Hopper Bottom Trailer (A50514)
2005 Wilson Hopper...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
toro turf sweeper (A50324)
toro turf sweeper...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
