X585 - What is Click and Go Kit
   / X585 - What is Click and Go Kit #1
RHWing
This is installed on the tractor I just got, I have the installation manual but nothing that tells me what it is for and it doesn't seem to match any of the implements or accessories I got along with the tractor.
Can't find any reference here on TBN forums or Deere.com.
Thank you,
   / X585 - What is Click and Go Kit #2
I have a x585 and yes it came with the "click-n-go" setup. It is used for the 3 bag powerflow bagger system, tractor trunk and a bracket to hang suit case weights off of the back for ballast. You can have both 3ph and "click-n-go" setup installed on back of tractor BUT you can only use one of them at a time. I believe there are several other things that uses that setup but the ones I mentioned above are the only ones I know about. Russ
   / X585 - What is Click and Go Kit #3
I have the Click and Go on my X595 tractor. I use it with a JD weight box while plowing and front-end loading (Johnny Bucket).
I think there is a "A-frame" attachment for it too....
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
TMA (A49461)
TMA (A49461)
2006 X-L SPECIALIZED 40TON RGN (A50854)
2006 X-L...
7021 (A50322)
7021 (A50322)
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
