VTtractorguy
Hi guys. I bought a new JD X540 tractor with 54 inch deck and am having a problem that hopefully you can help me solve.
I have had the tractor about two months now and in that time it increasingly has difficulty engaging the deck without stalling the engine. The manual says to engage the PTO at full throttle which I do. But even at that, engaging it takes the RPMs down at least half and stalls it about 50 percent of the time. After it has warmed up for a half hour or so it is less likely to stall. It usually makes a screeching sound when engaging, but I first assumed that was normal belt slippage before the blades get up to speed. Now I'm not so sure.
After each time mowing I always clean the clumped up grass out of the deck under and on the top. I hose it down and get it as clean as possible. I took the deck off and the blades spin freely (easily with one finger). I don't see any problem with the belt. No chafing or binding. I also engaged the PTO without the deck and there is no binding. It engages freely with very little impact on engine RPM.
So why does the engine not seem to have the power to recover when the PTO is engaged? It seems to run smoothly and has adequate power to run the deck once engaged and travel at any speed. My property has many sloping areas and the tractor has no problem navigating any of it.
Could there be a compression problem with the engine? Could lateral tension on the PTO and/or deck pulleys by the belt cause binding? Could the full throttle RPMs be set to low? I notice that after hosing the deck down it engages much easier. Is there something with lubrication? I have greased all the points specified in the manual. And as I say when the deck is off the blades easily turn.
Lastly, will stalling the engine from full throttle damage it? I guess the only saving grace there is the 4 year warranty...
Any help will be greatly appreciated.
Thanks,
Stewart
Thanks,
Stewart
