al3
Unit is 2 years old, sitting at 28hrs. 54 in deck has never cut well. Seems to be a combination of issues but mainly the grass height is grossly uneven across the right (grass chute exit) 50% side of the deck. I致e tried new Deere blades (that I checked on a granite base to insure flatness/parallelism), adjust the deck to both factory settings, also adjusted the deck to get the two outside blade tips to as close to the same height as possible, made sure deck vent holes are clear, underside is clean. Mow at a medium ground speed, full throttle, cut grass at 2.5 inches, and try to cut about 1-1.5 inches off when I mow. Grass is dry.
Deck is angle front to back by about 3/8 of an inch, gage wheels ス in clearance (on level concrete floor), tires at 10/14 psi. Pulled the blades off and measured jackshaft runout using a mag base and dial indicator; max of .011 runout horizontally, less than .002 vertically (i.e., the bottom of the shaft remains parallel to the ground. So doesn稚 appear shafts are bent----I致e never hit anything bigger than small sticks as I do my rough mowing with either a 4110 and brush hog or an old craftsman.
The 4110 also has a 54 inch finish deck available and when used cuts great. It痴 set up using the blade tip measurement. Deck on the 4110 has a plastic skirting material around the bottom left half.
Any thoughts?
Any thoughts?
