X485 Pressure in Transmission
   / X485 Pressure in Transmission #1
italyguy01
Pa
X485
I am hoping someone can help me, or let me know if this is normal. (only 130 hours on tractor)
When I start the tractor, the hydraulic motor is loud when operating the deck or turning the steering. A few times I shut off, and when I went to open the dipstick to check the oil level, a pressure was released. THe oil is full and then when I put the dipstick back in, and started, all is fine. This does this every time.
So Yesterday I used the tractor, same thing. This morning, BEFORE I even started the tractor I opened the dipstick and pressure was released. Is there a vent somewhere that is clogged? Or is this normal?
And if it does have a trans vent, can you tell me exactly where it is so I can check it.
Thanks in advance
   / X485 Pressure in Transmission #2
You can go onto deereparts.com and look at diagrams of your transaxle. I took a look and offhand don't see anything that looks like a vent. If the hydraulics have become louder than usual I would ask a technician at Deere . You might try changing the oil filter...
2013 PETERBILT 388 DAYCAB BOBTAIL VACUUM TRUCK (A53843)
2013 PETERBILT 388...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
2015 MACK CXU613 (A53843)
2015 MACK CXU613...
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
