X485 AWS rear tire replacement size
   / X485 AWS rear tire replacement size #1
Longwood01
Central, NJ
John Deere X485 AWS
Hi All,
I need some new tires for the rear of my x485 AWS.
There are 26 x 10.50 - 12 turf tires on it now and I can't find that tire size anywhere on line.
Has anyone replaced their rear tires with a different size?
   / X485 AWS rear tire replacement size #2
According to tractordata the x485 has 26 12 12 tires which are a popular tire. That is what I have on my x749 4x4ws mower and like the hdap tires a lot.
   / X485 AWS rear tire replacement size #3
It was pointed out to me in a PM a while ago that Deere does list the 26 10.50 12 turf tires for your machine. The question I wonder about is whether you can fit the more popular 26 12 12 tires. The pricing should be more competitive for popular tires I would venture.
   / X485 AWS rear tire replacement size #4
Hi All,
Radial tires for ATV's work well. Put an end to the spinning on hills here.
   / X485 AWS rear tire replacement size #5
On some models, the AWS rears are a smaller tire which may also be true (have not checked mine) for the X485.
And for spinning on hills, that is taken care of quite nicely by the AWS.
   / X485 AWS rear tire replacement size #7
Not necessary.. AWS works just fine for side hills especially.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
