x475 hydraulic whining
   / x475 hydraulic whining #1
Pittsfield, MA
2021 Branson 3515ch (hydrostatic cab)
Hey everyone!
Hoping you guys might be able to help with out with an issue I am having. My father owns a John Deere x475 and has had it for several years to mow his lawn, which is a couple of acres. Not sure exactly when he bought it but it has roughly 700 hours or so on it. It doesn't have a front end loader or anything like that on it, the only thing it is used for is cutting grass with the belly mounted deck on it.
Up until now everything has been working great on it but a couple of days ago he went out to mow the yard and it started to make a pretty loud whining noise. The noise starts almost as soon as you turn the engine on but usually stops, or at least gets much quieter whenever the hydraulics are in use. While raising or lowering the deck and steering the noise goes away but as soon as the demand for the hydraulic pressure goes away it comes back pretty quickly. Occasionally the noise will go away even after using the hydraulics but usually comes back in a few minutes. The hydraulics still seem to work alright, maybe a little sluggish but if it is it isn't super noticeable.
So he called me up and I had him bring the mower over to do a full service on it since it was in need of one anyways. We did pretty much everything, changed oil + filter, replaced fuel filter, replaced air filter, changed spark plugs but most importantly changed the hydraulic oil and filter. I was hoping changing out the hydro fluid and filter would fix the issues but unfortunately it was still there after we finished. When changing the oil it didn't look particularly bad or seem to have anything like metal shavings or other debris in it.
Any thoughts on what could be the issue or how I should go about diagnosing the problem?
Thanks so much!
   / x475 hydraulic whining #2
Having the service tech manual for the X475 would be good for chasing it down. Worth the few bucks, IMO.
   / x475 hydraulic whining #3
Just a shot in the dark here, but could be over-pressure.
Does the system have a pressure relief valve? I assume it does. Jammed, plugged, rusted in place?
Good luck,
Richard
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
JOHN DEERE FC20M LOT NUMBER 55 (A53084)
JOHN DEERE FC20M...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
