X360 HYDRAULIC DECK LIFT QUESTIONS
   / X360 HYDRAULIC DECK LIFT QUESTIONS #1
Gearz
Salem, NH
JOHN DEERE X584
I HAVE A 2013 X360 AND WHEN I PUT THE MACHINE AWAY AT NIGHT THE DECK IS RAISED AND IN THE MORNING THE DECK IS SITTING ON THE DECK WHEELS IT ALSO LOWERS IF THE MACHINE IS USED TO HAUL BRUSH AROUND THE YARD SO I HAVE TO RAISE THE DECK ALL THE TIME. DOES ANY ONE KNOW IF THERE IS A ANTI DRAIN BACK VALE THAT COULD BE FAULTY OR IS THIS NORMAL? THE TRACTOR HAS ONLY 3 HOURS ON IT AND THE FLUID FOR THE TRANSMISSION IS FULL WHEN COLD AND THERE ARE NOT ANY LEAKS THAT I CAN SEE. THANKS
   / X360 HYDRAULIC DECK LIFT QUESTIONS #2
Look in your manual and is if there is a way to lock it up when not in use.
I did look and there isn't a lock like the manual lift. That would make sense if there was a lock so I'll have to call the dealer and ask them because I can't find anything on the web.
   / X360 HYDRAULIC DECK LIFT QUESTIONS #4
Is it raised and lowered by the 3pt arms or does it have it's own cyl.
Either one, a cyl is bypassing or a valve spool is leaking. I would bet on the cyl seals.
   / X360 HYDRAULIC DECK LIFT QUESTIONS #5
Most hydraulic lift have this issue with john deere. If your going to be using it where don't want tit to drift down, your supposed to turn the height adjustment knob to the highest setting. That is the way you lock the deck in the up position.
Thank you that is really good advise. I will try that the next time I use the machine :)
   / X360 HYDRAULIC DECK LIFT QUESTIONS #7
I have 2 john deserves one is a 300 series with hydro lift and the other is a 3000 series. Both have hydro lift and they both bleed out. It is supposedly because of the design. They only have one hose going to cylinder. To lock them in place so they don't drift I have to use height adjustment at highest setting
So what your saying is that this is normal?
   / X360 HYDRAULIC DECK LIFT QUESTIONS #9
100 percent.
   / X360 HYDRAULIC DECK LIFT QUESTIONS #10
I don't like the design flaws but it is what it is. Good machines nonetheless
2011 HINO 338 24FT BOX TRUCK (A43004)
2011 HINO 338 24FT...
2005 Great Dane Trailer, VIN # 1GRAA96265S700587 (A44391)
2005 Great Dane...
John Deere 4052R (A44501)
John Deere 4052R...
2021 John Deere 6130M (A44501)
2021 John Deere...
Kubota ZG23F Zero Turn Mower (A44502)
Kubota ZG23F Zero...
1980 LINKBELT LS-318 LATTICE BOOM DRAGLINE CRAWLER (A45046)
1980 LINKBELT...
