X Series Rear PTO
   / X Series Rear PTO #1
lpavao
South Carolina
JD X585
Does anyone know what the diameter of the rear PTO shaft is for an X-series? Apparently (2) diameters are available according to JD, however within the selection sheet only 1 540 RPM option is identified. Also, can anyone tell me if the rear PTO is on along with the mid PTO - at all times?
   / X Series Rear PTO #2
I can't tell you the diameter, but the shaft is a standard 540 rpm PTO. There is a PTO selection lever that allows you to choose to run the Mid PTO only, Rear PTO only, or BOTH.
2017 INTERNATIONAL PROSTAR (A52472)
2017 INTERNATIONAL...
2024 KMC 7406 (A53084)
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2015 Ram 3500 enclosed service truck (A52377)
2015 Ram 3500...
