Tires Wrong tire size?
   / Wrong tire size? #1
Gussbuss1980
Wv
Kioti Nx 5510
Hi all new member and first time tractor owner. I recently purchased a new kioti nx5510. After reading through the manual it seems to me that the tractor has the wrong size tires on it. It has ag tires 9.5-16 fronts and 16.9-24 rears. According to the manual it should have 13.6-26 rears to match the fronts. Im worried the size difference will damage something in the driveline. Any input would be appreciated.
   / Wrong tire size? #2
Welcome to TBN..............
Check with your dealer. Tractordata also says it should have the tires you mentioned. Maybe they swapped them out on another tractor before your purchase.
   / Wrong tire size? #3
As long as the rolling ratio is the same as the originals, it should be OK with larger tires on both front and rear. The fronts should travel around 5% faster than the rears.
   / Wrong tire size?
The front tires are the correct size, the rears are like 2 sizes smaller thats why i was concerned.
   / Wrong tire size?
Thats what im kinda thinking George that they were swapped. It has 2 options for the ag tires 9.5-16 and 13.6-26 or the 9.5-18 and 13.6-28. No where does it show that rear tire size thats on it now in the manual.
   / Wrong tire size? #6
I just found this spec sheet on the Kioti site for an NX5510, NX5510HST, and NX5510CAB. It does show 9.5-16 front and 16.9-24 rears for Ag tires. You sure you have the right owners manual. There are other sites that do show 13.6-28 rears on the NX5510. Might want to have the dealer verify they are correct. I'd have the factory rep verify whether the factory web site or the owners manual lists the correct sizes.
The NX5510C Utility Tractor | Kioti Tractors
   / Wrong tire size?
Thanks for the info George. Looking more at the manual it does show that option but for the 4510 and 5010. But shows the larger tires for the 5510 and 6010.
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
2015 CATERPILLAR D9T HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
