Wreched broadcast spreaders!!!!!!!!!
   / Wreched broadcast spreaders!!!!!!!!! #1
js5020
Platinum Member
NE PA
Kioti CX2510, Kubota BX23S, AC5020, JDx300R
Well I've about had it with these overpriced pieces of JUNK!!!!! In the last 3 years I had to buy 2 of them, the first one cost me around 85 bucks and it lasted through seeding the yard, fertilizing and liming twice,,,not to bad actually it's just a little thing the wife bought,,, the second one was an argi-fab unit, looks nice, big tires, easy to turn off and on, nice unit cost about 150 bucks,,, the first time I used it I thought I finally had a good one. Well had it out for the second time the other day and the gears gave up the ghost while spreading granular lime,GRRRR. I am not buying another one,,,,,, and why am I posting this in the 2 wheeler section?? Well this modification is gonna involve 1/2 the junk spreader and I'm thinking a Gravely rotary plow gearbox! I want to see it rip the gears out of that!!! Well at least that's my plan A. Updates to follow.......
   / Wreched broadcast spreaders!!!!!!!!! #2
Maybe you're buying models that are too expensive.:D I have a $15 Scotts hand held spreader I've used for over 4 years and it's still like new. My daughter has a Scotts walk behind and push spreader that cost less than $30 and it's also over 4 years old. Before I moved back to town, I had a Craftsman that I pulled behind a riding mower. I bought it used for $30, but I've never had a problem with any of them. I do clean them pretty thoroughly after each use.
You maybe right Bird, the cheaper one did last longer than the more expensive one did! It just frosts me with these things. I only spread granular fertilizer and lime, when I buy it I make sure it's dry and use it right away. I also wash things up after use and grease it before and after. Tomorrow, I'll either have one that spins or I'll twist the shaft in two!
Well in between rainstorms I have managed to make some headway on this thing, working outside,,,,I have the spinner mounted and had the tub temporarily mounted, and even applied some power and spread some sand. I have to mount the tub permanently before I can get a good idea what kind of spread pattern it makes, but it does work, just don't know how well yet.
   / Wreched broadcast spreaders!!!!!!!!! #5
Hmmm my $30 spreader is 15 years old. But then again I have no shame in the amount of tie wraps and epoxy that I will use to "fix" it one more time.:rolleyes:
Post some pics of the Gravely set up when you get a chance. It sounds interesting.
   / Wreched broadcast spreaders!!!!!!!!! #6
I have a related anecdote:
A buddy of mine works in a metal machine shop, and one of his ongoing projects for a customer is custom-machining a lime-spreader out of solid stainless steel. It has to be perfect, solid, polished, 100% stainless. It has to spread lime perfectly. Cost is no concern here. Perfection takes priority for this customer. At the price of stainless steel these days that's gonna be a pricey tool. A lot of people are quite particular about their garden tools.
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
Wolverine Quick Attach Screening Bucket (A50515)
Wolverine Quick...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
John Deere No. 5 Sickle Bar Mower (A50515)
John Deere No. 5...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2017 Nissan Titan Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
