WR Long solenoid question
/ WR Long solenoid question #1
jcliburn
Lawrence County, Mississippi
Kubota MX5100
I'll call WR Long in the morning, but I thought I might get a quick answer here first.
I've installed a WR Long 3rd function electric over hydraulic valve kit on my Kubota MX5100, but the solenoid kicks in only one direction. Press the rocker thumbswitch in one direction: CLICK! Press it in the other direction: nada.
Opened up the switch and swapped the connections: same behavior, different switch direction.
Swapped the wires at the splices down near the solenoid: same behavior.
I guess at this point I need to know if the solenoid *should* kick when the thumbswitch is pressed in either direction.
Thanks,
Jay
/ WR Long solenoid question #2
Yes, it should "click" in both directions. Sounds like a bad switch or loose connection. Do you have a voltmeter?
Voltage checks good down at the splice points. 12 volts on each wire depending on which side of the switch is pressed.
/ WR Long solenoid question #5
Give Nelson time ... he'll be in here as soon as he reads this.
/ WR Long solenoid question #6
Have you actually tried using it, with the tractor running? There may be pressure in the line and it won't switch-just a guess...
@blueriver: Thanks, I'm sure Nelson will be on top of it.
@kennyd: Yes. I hooked up my new grapple tonight and tried to operate it. No joy. In the "working" switch direction, the hoses jump and the engine bogs a little. In the other switch direction, nothing.
I'm thinking the "working" direction wants to close the already closed grapple. I suppose I could swap hoses at the grapple to see if the "working" direction will open it, but I'd have to swap QD fittings to do it.
/ WR Long solenoid question #8
There are a number of potential causes.
This is how I go about working the problem.
1st I check to see if it is an electrical or hydraulic problem. This can be determined by operating the valve manually.
There is a small round brass rod at the end of both sides of the valve where the solenoid is located. The solenoid is held in place with a plastic nut and through the hole of this plastic nut the brass rod can be seen. It is indented and a small phillips head screw driver can be used to put this rod. Crank up the tractor and let it run in idle. Push this brass rod in. It will go easy about 1/2" then it will be harder to push for about 1/4". This remaining 1/4" movement operates the valve manually. Do this on both sides (one side at a time). If your attachment works then the hydraulics are fine and there is a issue with the electrical side. If it does not work the there is a issue with the hydraulic side.
ELECTRICAL:
1 - Check the switch, which you have done.
2 - There are two small screws that hold the terminal block on. (plastic piece with two wires coming out on top of the valve). Make sure the two screws are tightened. These screws make the connection to ground the valve to the tractor.
3 - A solenoid may be bad but this is extremely rare.
4 - The connectors inside the terminal block may not be connecting to the 2 post on the solenoid. Again extremely rare.
HYDRAULIC
1 - The quick connects may not be completely connected. In your case this is not the issue since you are getting flow in one direction.
2 - The quick connects could be bad and either act like a check valve or completely block flow in both directions.
3 - The valve could be sticking however when it is operated manually this will unstick the valve.
4 - It is Possible that the "P" and "T" hoses are connected backward. Make sure that the flow of your hydraulic fluid is from the power beyond port of your loader valve into the "P" port of the W. R. Long valve.
Hope this helps.
Nelson
W.R.Long Inc.
Thanks,
Jay
Thanks Nelson. I'll have a go at the recommended procedures when I get home from work tonight.
The P and T ports are correctly connected. In the picture below you can see your hose (with lettering) connected to my loader PB port. The other end of that hose connects to your P port.
In the picture I can also see one end of the brass rod in the center of the black end-cap nut (just above the two quick disconnects). I'll try and manually operate it as you describe. Should be "fun" trying to work in that space with the loader mounted and all the hoses connected. :(
Nelson, I found the problem: The screws that mount the connector block to the valve body are a little too long, and they bottom out before making solid contact with the ground tabs (the square silver pieces under the screw heads in the photo below). I inserted a washer under each screw and everything now works. Unfortunately, the connector block plastic cap won't fit over the washers.
I called and asked Don to send a new connector block, hoping that the screws are shorter or the ground tabs are thicker.
Another option, I suppose, is to cut a couple of millimeters off the screws, but I'm loathe to do that because the threads are so fine.
Thoughts?
I fixed the problem by tightening the lower screw to about 7,000 ft-lbs. :) Although the screw was already quite "tight" right out of the box, it didn't make contact with the ground tab underneath it, and I was able to wiggle the tab with my finger. So I tightened and wiggled, tightened and wiggled, and tightened some more until I finally couldn't wiggle the tab. No washers needed. No screws cut.
Both solenoids now work correctly and the grapple is in operation.
/ WR Long solenoid question #12
Good info JC, thanks for reporting back:thumbsup:
/ WR Long solenoid question #13
Glad to hear the source of the problem was discovered. I don't remember having that problem before. We sent the screws and terminal block last week.
Nelson
Thoughts?
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2022 EZ-GO ELITE...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
