WR long 3rd attachment issue
   / WR long 3rd attachment issue #1
Dale baughman
Kioti dl5510
Hooked up my grapple. Arms open one at time very slow. Close same way. Replaces quick couplers on grapple, no help. Took solenoids off clean it all put back on, no help. Pushed the cooper pins in to free them. Now my tractor is making loud noise at the hydrolic pump I think ? Tractor is new only 64 hr. Any ideas ?
   / WR long 3rd attachment issue #2
Do you have rear remotes? Make sure both are in neutral position.
Does the 3 pt lift and lower normally?
Loader raises and curls normally?
   / WR long 3rd attachment issue #3
You did all this yourself? So now it doesn't work right, and the tractor system makes noise?
I see (at least) two possibilities here. 1) You can try to explain what you have, what you did, how and where you hooked into the tractor system. Maybe post some detailed Photos of what all this amounts to, and hope for some reasonable answers. That might happen, but will also get you a number of "do this, do that, try the other, and all that" Most will likely contain conflicting information, and keep you going back and forth for days.
2) You can try to find someone local that knows what they're doing to come and look at it. That person will probably find your problem in less than ten minutes.
   / WR long 3rd attachment issue #4
Sounds like you may have plumbed something wrong. As in wrong connections. If you crossed connections you may have inadvertently dead-headed the pump and the noise you are hearing is the relief valve.
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A47371)
Wolverine...
INOP/NON-RUNNING 2012 Ford F-450 Pickup Truck, VIN # 1FD0W4HT2CEC31215 (A48836)
INOP/NON-RUNNING...
2015 KENWORTH T800 (INOPERABLE) (A48992)
2015 KENWORTH T800...
2000 John Deere 2700 (A47164)
2000 John Deere...
2009 Chevrolet Cobalt Sedan (A46684)
2009 Chevrolet...
45016 (A48082)
45016 (A48082)
