SmallChange
Platinum Member
- Joined
- Apr 19, 2019
- Messages
- 750
- Tractor
- New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
Just finished my first coolant change on this tractor, which I bought new. This included removing the drain plug from the engine block.
Wow! It sure was tight! There's an assembly kind of in the way so I had to use a universal joint on the 14 mm socket. First I tried my 1/4" ratchet drive, which fit into the space with as little angle as possible, but couldn't get enough torque. So I went to 3/8" drive ratchet. Couldn't get enough torque on that either. So I went to my 1/2" drive using a breaker bar that's probably 18" long, and even that I couldn't get enough torque at first. I had to squeeze into a better position to do it. I'm going to estimate about 50 foot pounds it took to loosen it. Then it was perfectly easy. The threads looked to me about like a 1/4" NPT, but I'm just eyeballing it to describe it, and I suppose it was probably a metric thread that I just can't recognize by sight.
The plug was clean, with no thread sealant as far as I could tell. Hole was clean too, as well as I could see it. When I put the plug back in, I used PTFE tape on it, and probably got less than 20 foot pounds torque, which still seemed like a lot for something pretty small that I'd hate to strip. I think PTFE tape makes the torque to install today, and the torque to remove in a couple years, more similar. That is, it helps prevent getting the thing stuck.
Why so tight? And why don't they put any sealant on it (or at least nothing I could see)?
