Would this be worth buying? Need a 4wd mower and sofar it's far cheaper than buying a new lawnmower
   / Would this be worth buying? Need a 4wd mower and sofar it's far cheaper than buying a new lawnmower #1
Boganism
None
   / Would this be worth buying? Need a 4wd mower and sofar it's far cheaper than buying a new lawnmower #2
The garden tractor looks rather dated. Have you checked on parts availability?
   / Would this be worth buying? Need a 4wd mower and sofar it's far cheaper than buying a new lawnmower #3
Yep, dedicated dealership about 30-50 mins from me (close for Australia lol) and a partswide dealer for Kubota parts that ships from the state over, so overall there should be semi okay parts availability
   / Would this be worth buying? Need a 4wd mower and sofar it's far cheaper than buying a new lawnmower #5
So it seems it was built from 1983 to 1990.
   / Would this be worth buying? Need a 4wd mower and sofar it's far cheaper than buying a new lawnmower #6
Looks tidy, low hours, decent deck, Service history...
If the seller seems reputable - Grab it.
You can always re-sell it if you don't like it.
(For the Americans - Gumtree is an Australian equivalent to Craigs List -ish)
   / Would this be worth buying? Need a 4wd mower and sofar it's far cheaper than buying a new lawnmower #7
I personally shy away from MMMs because they are in the way when you are doing normal tractor chores and to clean out the deck during the wet grass season is a king sized PIA. I buy tractors to do tractor jobs and mowers to do mower jobs.....FYI, I use one of my tractors to lift the front ends of my mowers when it's time to get the hose out and washout the deck, and while doing that, I remove and sharpen the blades. By doing it that way, I can move my washout spot around the place so that I don't wind up with a fixed spot and piles of clippings and mud to clean up.
   / Would this be worth buying? Need a 4wd mower and sofar it's far cheaper than buying a new lawnmower #8
My MMM goes on and off every week and I do have 2 Z-turns, just can not use them on the steeper slopes and rougher parts. Also use a Brush hog for the tall stuff. MMM is easier to install and remove than the brush hog, mostly because I rarely use the brush hog. Once the MMM is off the machine and standing edge it's way easier to clean than my other mowers.
   / Would this be worth buying? Need a 4wd mower and sofar it's far cheaper than buying a new lawnmower #9
It’s a tractor, not a garden tractor. If it doesn’t have an end loader no problem taking the mower off and on, it can stay on. It is a quite a bit older Kubota.
I was initial concerned, before realizing I'd had the deck off the lawnmower for the last weeks so it wouldn't make a difference lol, but you do raise a really good point about cleaning
Killbros 260 Seed Conveyor (A52748)
Killbros 260 Seed...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A52748)
UNVERFERTH 330 -...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2011 FREIGHTLINER M2 (A52472)
2011 FREIGHTLINER...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
