Would these tires fit my FT 360?
   / Would these tires fit my FT 360? #1
rogdan
West Virginia
Farmtrac 360 DTC TLB
I know that the bolt pattern would have to be the same on the rims, these are AG tires off of a Massey Ferguson 1260; rear 13.6x24 and front 8x16. I bought my FT with industrial tires and I'd like to be able to do some work this spring and not wait until things dry up later in the summer.
Is this a crazy idea?
   / Would these tires fit my FT 360? #2
Couple other things to check is heighth of rear tires to see if they will clear fenders and make sure the offset in rims will allow the proper clearance on inside of tire in relation to fender. Make sure fronts are not to tall that when in full turn you catch the tractor or loader and the offset on them will allow clearance to front hubs. Hope they work out for you.
Thanks Tim,
I am wary now that you mention clearance with the front tires, the industrials that I have now will catch the FEL lines with a sharp turn at times.
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
Electric Concrete Mixer (A51573)
Electric Concrete...
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
Huskee 20 Ton Wood Splitter (A51573)
Huskee 20 Ton Wood...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
378812 (A51573)
378812 (A51573)
