Would Power twist V belts suffice on my NAA?
   / Would Power twist V belts suffice on my NAA? #1
krogers
ford jubilee
   / Would Power twist V belts suffice on my NAA? #2
I have read about them being used like that but I have no idea as to the life of the belt when used that way. It does seem that as long as it fits and sits down in the pulley correctly it should work. After all there is not much load pulling the water pump and generator.
Ya, I hope your right although I also have to turn the Hydraulic pump for the loader. It's mounted forward of the engine.
   / Would Power twist V belts suffice on my NAA? #4
Your hydraulic pump is belt driven? The loader pumps are usually driven off the crankshaft with a coupler.
The pump is driven by shaft coupled to the pully. So your comment made me think, "He's right, the pump is not turned by the belt". Thanks for your help.
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2021 JCB 3TS 8T SKID LOADER (A51242)
2021 JCB 3TS 8T...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
3 pt Aer-Way (A50514)
