Would either 5 or 6 hp be enought to power a 3 gpm pump?
   / Would either 5 or 6 hp be enought to power a 3 gpm pump? #1
chad22
Veteran Member
Kansas
Sears Garden Tractor
I see some 5 and 6 hp gasoline engines cheaper than the 13 hp and would like to get the cheaper engine if it would work?
Would a 5 or even 6 hp be enough to power a 3 gpm pump without bogging down? Would those size engines be sufficient for a little towable backhoe?
Or should I go with the 13 hp?
Chad
   / Would either 5 or 6 hp be enought to power a 3 gpm pump? #2
A single stage pump of 3 GPM and 3000 psi, will require abut 6 HP.
   / Would either 5 or 6 hp be enought to power a 3 gpm pump? #3
It depends on flow rate and PSI as well as cylinder size and actuall work realized.
Me, I'd get a 13 horse Honda and be done with it.
   / Would either 5 or 6 hp be enought to power a 3 gpm pump? #4
With a 13 HP, you could power a 6.5 GPM single stage pump, at 3000 psi.
A 13 HP motor could also power a 22 GPM two stage pump at about 650 psi, and about 7 GPM at 3000 psi
Probably not a good idea to use a two stage pump on a BH, as the speed and power would change as you approach the 650 psi switch over.
Using the 13 HP engine and 6.5 GPM at 3000, and a 4 in cyl and 2 in bore, the extension speed would be about 12 sec, and retract would be 8.8 sec, for a total cycle time of 20.8 sec
The 3 GPM will provide about half of the above.
Possible 18 ton using the 3000 psi
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2025 Star EV Capella Electric Cart (A51694)
2025 Star EV...
