would a bx-1500 do?
   / would a bx-1500 do? #1
howardx
I have about 3acres with a house, and plan on putting in about 1/2 acre pond.So, I'm only going to need to finish mow about 2 acres. I would like to be able to do some light landscaping chore's (dig some holes for fence,deck,dock,etc., use the FEL for a wheelbarrow and light ground engagement.) I'm intriqued by the kubota bx1500.. Is it powerful enough to do what i want? I'm trying not to spend the big money for the bx-23 or bx-24 if i don't have to.
thanks for the input,
howard
   / would a bx-1500 do? #3
howard
2-3 ac is pushing it for rider-lawnmower teritory.. but fine for SCUT like you mention.
Soundguy
   / would a bx-1500 do? #4
Being an owner of a BX1500, I can tell you that it will do what you describe just fine. I have the loader, 54" mid mower, toothbar, and 4' box blade for mine. I'll list some of the chores that I've accomplished with mine in the 9 month's and 55hrs run time that I've had it:
- Mowed our 1/2 acre yard on a hillside probably 15 times so far. Parts of it are up to 30 degrees slope and I'm able to mow going sideways no problem especially after filling the rear tires with winter formula windshield washer fluid. Takes about 45 minutes per cut with the 54" deck but that is mostly due to having to cut around the house, trees, driveway etc.
- Moved and spread probably 100 yards of topsoil at my father in laws and fathers houses
- Moved and spread 12 tons of gravel and did some miscelaneous dirt work and dressing up in the back lot of the office where I work. That was a paying gig!
- Hauled and spread about 16 yards total of pine mulch at my Mom's house and my own house
I've accomplished some other things with it, but I've hit the high points above. Overall, it is a little workhorse. It does have it's limits, but all tractors do. Hope this helps!
   / would a bx-1500 do? #5
I don't have one, but one guy on here who goes by the name blackmajikwoman put a Woods BH6000 backhoe on a BX1500. He posted numerous photos of the ditches he dug, rocks moved, etc. with the unit. If you go to the search page, and search in the Kubota Owning and Operating forum for "BX1500 BH6000" or "BX1500 backhoe" you should be able to find the threads and posts he put up. It was pretty amazing. This isn't to say that you need a backhoe, just that the BX1500 did something I didn't think it would be able to.
Still, if you think you ever will need to run a chipper, generator, rough cutter, tiller, etc. off the rear PTO, I'd go with a BX2350, just because you need more hp there to run those things. That backhoe runs off the hydraulics and these others require the PTO.
   / would a bx-1500 do? #6
howard
Coming from a man of limited experience...for the grass cutting...certainly...for the other jobs..Id say a definate NO! I bought my Kubota last fall..and I looked at various BX models till I was sick of seeing Kubota orange paint..lol
I shopped JD ( boy.are they ever out of their A** when it comes to pricing!!!) NJ...Kubota..etc. I CAREFULLY explained what my intended usage would be. ( No mowing in my case at all) To a dealer they all said NO! to that size ( and I never intended on installing a BH at all..too much $$ for my limited usage)
I moved up a size...(B2630 as an example) but my farmer friends FINALLY talked me into getting the 30HP model ( the stinkers...lol)
If $$ are "tight" ( they are in my case at least) Id look at a slightly used larger model...around here...NH "TC-29's adnd TC 30's are hot used items. I came withing a breath of getting a TC29 with FEL on it that had 400 hours on it..
   / would a bx-1500 do? #7
howard
Howard,
I bought my bx 1500 in March of 2005. I just turned 200 hrs, about half mowing (48"mmm) and half FEL work. I think the bx1500 is perfect for your needs as you described them. I have moved tons of dirt, wood chips, rock, lime (messy) with the loader. I have never lacked for power. I have also used the loader to move snow in the winter. Manuverability is great, especially in close quarters.
The only potential problem I see is with digging holes. I assume you are planning on using a 3ph post-hole digger. You may have issues with adequate clearance (height) based upon other posts I've read from time-to-time. You may want to do a search on bx 1500 and post hole digger or phd for more info.
With due respect to the last poster, I think a b3030 is way overkill for the use you described.
   / would a bx-1500 do? #8
The poster who says you need a B3030 also says that he is "a man of limited experience." I think he is being honest and though I do not wish to dis him, I agree with that assessment. In this case, a B3030 would be like buying a 17 passenger van for one person to use on a short commute to work.
coveredbridge is right about the post hole digger. This goes back to what I said earlier about the hp at the rear pto. Also, you have a 3 point hitch that is not full sized. I can barely get a full sized PHD on my BX2200. I think you would not be able to fit the U-bar on your 3ph and I doubt that you'd get enough lift for a standard auger. There are, however, a couple of PHD's now made for sub-CUTs, which would probably fit if coupled to a 30" auger. Land Pride and Gearmore both make small PHDs and Pengo has a 30" auger. That still leaves the hp question at the rear pto. If you have sandy loam without rocks and heavy roots and use a narrow diameter auger, you may be ok. If, however, you want to use a wider auger, dig in hard soil and/or soil with rocks and tough roots, I think it could be problematic.
Also, if you ever did put a Woods backhoe on the BX1500, the sub-frame does prevent the 3ph lift arms from going to their full height IF they are also spread to their absolute maximum width.
   / would a bx-1500 do? #9
READ CAREFULLY! I "NEVER" STATED the man needed a 30 HP machine..now did I??? What the INTENT of my post was...is EXACTLY as other have indicated..in their own words. The PHYSICAL SIZE of the "smaller" tracors..WONT HACK IT. The PHD dont work "correctly" unless you spend the $$$ to buy the "special size" for SUB-CUT's ( hence..you aint going to borrow your farmer buddys to bore 6-8 holes with...your going to lay out $500 or more to bore those 6-8 holes!!)..etc..etc.
The FEL on Scuts is TINY..lifting capacity is SMALL..etc..etc.
I just thing this gentleman would be better off all around with a LARGER..PHYSICAL SIZED machine..25-26 HP would be enough..AND.if $$ is tight..??...buying a USED MACHINE..that size or a little large..SHOULDNT be out of the question.
So PLEASE dont make my post sound like ..because of my limited experience..that "I" sugest he get the MEGATRON 5000 with 250 PTO HP and weighing in 15K pounds!
Just for reference...
"Also, if you ever did put a Woods backhoe on the BX1500, the sub-frame does prevent the 3ph lift arms from going to their full height IF they are also spread to their absolute maximum width."....!!!
   / would a bx-1500 do? #10
howard
I had a BX1500 two tractors ago. It was a great little machine. I used the belly mower, bagger, snow blade, and the loader. I loved the 4wheel drive. Keep in mind, with 15hp total, after the hst loss, the pto hp is low, so you can't run large rfm's or brushhogs. I'd buy one again.
Cat TH407C Telehandler (A52748)
Cat TH407C...
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
Year: 2015 Make: Toyota Model: Camry Vehicle Type: Passenger Car Mileage: 109,107 Plate: Body Type: (A51694)
Year: 2015 Make...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
