chim
Elite Member
I did the 100 hour maintenance today on the 7500. One thing that surprised me was the rear wheels were loose. The lugnuts were good and tight, but when I checked the bolts that go through the hub and axle, both were loose. I'm not sure what the proper terminology for the bolt is, but it's the one that you remove to set the wheels to different widths. Now I see why Kubota puts the pins through as a safety measure. I snugged them well and ran around the yard for a while, then retightened them. Driving around did seat them enough to let me tighten them a good bit more. Next time I use the tractor, I plan on checking them again.
Had a good workout bush hogging for a couple hours after servicing it. What a great day to be outdoors here in PA...............chim
