Tires Worry about tires
   / Worry about tires #1
Anonymous Poster
Epic Contributor
Has anyone ever tried to lift something with the bucket and it is too heavy so the bucket pulls up the back of the tractor and squishes the tires? I was wondering would this hurt the seal around the tire?
   / Worry about tires #2
Sure, Mack, I've almost flattened the front tires a few times, and I don't like doing that; I figure it can't be too good for them, but so far I've never had any tire problems. Of course, I try to have enough counterweight to prevent it from picking up the back wheels.
Bird
   / Worry about tires
I am sure I have plenty of counterwieght though. About 2000 lbs of backhoe wouldnt that do the trick?
   / Worry about tires #4
It shouldn't hurt the bead (the part that seals against the rim) but it could easily damage the sidewalls. As Bird says, enough rear counterweight will keep the front end from being lifted off the ground. And another thing it accomplishes is that it reduces the weight on the front tires, as long as it's enough to keep the rear tires on the ground, of course. (If you need 500 lbs on the rear to keep the rear tires on the ground, and you put 400 back there, when the rear tires come off the ground, all you did was put an additional 400 on the front tires.) Think of the tractor as a being a fulcrum with the pivot point being the axle with the most weight on it. You could conceivably put enough weight on the rear that the front tires would come off the ground. If you did that, there would be no weight on the front tires until you put a load in the bucket, at which point the weight on the front tires would be the amount needed to bring the front end back down plus the balance in the bucket.
   / Worry about tires #5
If you're flattening the front tires with the backhoe on it, you need more air in the front tires, better tires, or ballast in the rear tires.
   / Worry about tires #6
Mack, Mark talks even more than I do/w3tcompact/icons/smile.gif, so he gave you more detailed information in his two posts. And he's got it right, too, of course.
Bird
   / Worry about tires #7
Speaking of tires, I don't have any kind of weights or water in the tires. The extra weight might come in handy when I'm trying to pull up trees, but I operate in extremely thorny conditions and my tire sealant is doing a wonderful job. Have not even had to add any air to a tire since I put sealer in the tires last year after having a flat the first day mowing my property. If I put water in there, all those thorn holes will probably spring leaks.
What would set of wheel weights for the 2710 cost?
   / Worry about tires #8
Alan L. - What kind of tires do you have on your 2710?
   / Worry about tires #9
Bird, while we're on the subject of almost impossible things, do you think you'll ever be in Virginia again?
   / Worry about tires #10
Mark, I really have no idea, but I'd say it's doubtful, except for going directly from home to Princeton, WV, where my wife still has family.
Bird
1989 Freightliner Cabover FLA086 (A52128)
1989 Freightliner...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2012 CHEVROLET SILVERADO 2500HD (A50854)
2012 CHEVROLET...
Land Honor Quick Attach Big Arm Backhoe (A50515)
Land Honor Quick...
BUYERS PREMIUM & PAYMENT TERMS (A52141)
BUYERS PREMIUM &...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
