Workmaster 55 Tachometer and fuel gauge questions
   / Workmaster 55 Tachometer and fuel gauge questions #1
MrWhippy
Maryland
Ford 1710, Ford 5600, NH Workmaster 55
Sometimes, especially when the temperatures have dropped in the last 24-48, the fuel gauge and tach fail to register a reading while the tractor is running. Sometimes they will suddenly begin to respond to the sending units and read correctly. Sometimes not. The problem is very sporadic. I feeling is likely a spade connector needs to be better seated and that when the temps drop, there is enough shrinkage that there's a poor contact until the tractor heats up sufficiently.
Anybody else seen this? Suggestions on other possible explanations?
   / Workmaster 55 Tachometer and fuel gauge questions #2
I have a 2013? Workmaster 55 that has done this since it was practically new. Did you happen to find a solution?
MINI EXCAVATOR BUCKET 12" (A50322)
MINI EXCAVATOR...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2012 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A52141)
2012 VOLVO VNL...
John Deere 850 Tractor (AS IS) (A50774)
John Deere 850...
