Work Lights
   / Work Lights #1
Dude Man
South East Wisconsin
Bolens ST160
Hi, I am trying to find some halogen work lights to put on my tractor cab. It is a Curtis Hard Side Cab with the 3/8" holes drilled in already. I already have the switch and wiring too with bullet connectors to go to the light. I can change the type of connection if needed. Any suggestions would help with a description and price.
thanks
dude man.
   / Work Lights #2
I put 4 3x5 trapezoidal lights on my tractor from Messicks. These are high quality lights with very sturdy mounting hardware-not the stuff you'd find at Wally-World.
   / Work Lights #3
I put two Peterson 4" x 6" trapezoids and two 4" x 6" floods on mine, and I got them from Northern Tool.
   / Work Lights #4
I just put a pair of these OPTRONICS COMPETITION SERIES DRIVING LIGHTS - CarParts Quality Discount Parts and Accessories on my 5030.
I am highly impressed. They put out at least twice the light as my OEM Kubota work lights that I replaced. The write up on them on the web page is wrong. They are 50 watt MR16 bulbs; very bright and they come with wiring and switch. Can't beat the price either.
(since I was already wired and switched, I was plug and play.)
I am buying a second set to replace my rear oem Kubota work lights. I got the idea of mr16 work lights after I saw them on a Deere dozer.
   / Work Lights #6
They are 12 volt mr16's. A clean and bright adaptation; like I said, I am getting more for the rear work lights...twice as bright as kubota oems.
   / Work Lights #7
Anyone having a problem with the globes going out of the lights? Maybe my tractor is a rough ride but my lamps have burned out twice in a year...
   / Work Lights #8
And what about a set or work lights, or 1 real bright one that has an on/off switch on it? This way we can wire it in to the headlights, and only turn them on when we need.
   / Work Lights #9
Is this the only thing burning out of could your voltage be high? At same time are you sure they are burnt out and not a loose connection? I replaced a few tail light bulb before I realized the bulbs were fine and it was a connection issue. kt
   / Work Lights #10
What I find works real good is the 'driving or white halogen fog lights' that often are offered at auto parts or maybe WallMart at about $10-15. per pair! (usually blister packed)
Being 'fog lights' they put out a flat wide beam that is 'just right'. So much so that I only need one front and back and my entire work space is well lit.
Before I needed 2 front and 2 back of the old metal tractor work lights that always ended up rotting/rusting to death.
Also the 4" tractor light sealed beams actually cost more than the driving/fog assemblies.
Trick is to find the clear ones and not yellow.
Also the hallogens put out more light per watt than the old sealed beams!
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A50324)
2008 Nautica...
2024 Bintelli Activ-EV Pulse (A50324)
2024 Bintelli...
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
2010 FORD F150 WORK PICKUP TRUCK (A52141)
2010 FORD F150...
