Work lights for TC33D
   / Work lights for TC33D #1
SCOTTO
FRANKFORT, IL
NEW HOLLAND TC33D
Wheres the best place to get work lights (on the internet). I have a TC33D and want to install auxiliary lights. I looked at a lot of threads on TBN but still am unsure. Whats the best way to and wire? I have a FEL and would like to attach them to the ROPS. (2 forward and 1 rearward). Any advise would sure be appreciated.
   / Work lights for TC33D #2
I just purchased a TC35D which is a step up from yours. I have a sun canopy in which I mounted two aux. lights in the upper corners, purchased at a local tractor supply store ( about $20.00 ). I then purchased a headlight rocker switch from New Holland that fits nicely right into the panels on the dash ( about $13.00 ). Heres where the fun starts. I ran a hot wire ( used 12 guage) from the battery to the switch. Because this switch has five terminals in the rear, I connected the hot ( power ) lead to terminal #5. The ground terminal is #7, which was grounded to the frame. The lead to the lights has an inline fuse and went to Terminal #6. To make the switch illuminate at night, I tapped the instrument panel light wire and connected that lead to Terminal #2 ( The blue wire going into the instrument panel marked 054 was the one used ). To access these wires and make the job easier, remove the instrument panel ( two screws in front) and the lower left black panel ( when sitting in seat) . Raise your loader, if you have one, all the way up to gain access under the hood. Everything should be o.k. I hope this helps.
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
Land Honor Skid Steer Winch (A50515)
Land Honor Skid...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
Kivel Pallet Forks (A47384)
Kivel Pallet Forks...
3001 (A51691)
3001 (A51691)
2013 Freightliner M2 106 Altec AA755 55FT Bucket Truck (A50323)
2013 Freightliner...
