Work light connector for New Holland - solved!
   / Work light connector for New Holland - solved! #1
BarryJB
Elfin Forest, CA
New Holland TC29DA
Hi folks,
I decided to add rear work lights to my TD29DA, but didn't want to use the factory kit.
After fruitless searching on line for the SAE-like two-conductor rear-work light connectors fitted to the factory harness - they have extended pins with extra insulation to create a weatherproof seal - I hacked mine off and used ordinary SAE connectors, the type commonly used on motorcycles and Battery Tender cables.
HOWEVER:
About a month later, I came across the CORRECT style of connectors in a marine supply store - they are sold as TROLLING MOTOR connectors, and as such also have a generous wire gauge.
I hope this helps others avoid the pain of unnecessary surgery :)
   / Work light connector for New Holland - solved! #2
Thanks for the post. I've actually found those connectors at a trailer supply store and Radio Shack also. It's a pretty universal connector from what I've found from my years in automotive. It's still great information to have! Thanks!
2014 Deere 304K (A50120)
2014 Deere 304K...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
General 7000 EXL 7000 Watt Generator (A50322)
General 7000 EXL...
2023 Third Coast Equipment RA12H Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2023 Third Coast...
2021 Honda TRX 420 4x4 ATV (A50324)
2021 Honda TRX 420...
