Woody1934
   / Woody1934 #1
Woody1934
I'm a newbee to tractors and I'm confused by spec sheets that contradict themselves. For example, I went to Kubota's website to check out the L3400 and L2800. The spec sheet shows the L2800/L3400/L4400 all with 4 cyl. diesels, with each sucessive model having a few more cubic inches. When I go to the Competitive Comparison display, the tractors compared with the L3400 Kubota all are said to have 3 cyl. engines, including the L3400. Which spec sheet should I believe? Also, I find it curious that both the Main and the PS hydraulic pump capacity on the L2800 is greater than on the L3400. In any case, both the L2800 and the L3400 are shown to have the same lift capacity.
Next question: Referring to the Rear PTO; What does "Live Continuous with ORC" mean? This comment is listed with the L3400HST 4WD. My last question has to do with your recommendations for buying equipment to take care of 15 acres of moderately sloping land, the center of which is grass (85%), surrounded by woods (15%). There will be a half-acre garden to establish, numerous tree plantings and post holes to do. I'll have a 200 ft. driveway to maintain and I'll probably want to clear out the underbrush in the treed areas and, perhaps knock down a few of the smaller trees to establish an open grove effect. I don't know yet what drainage problems I might have to solve. But the land is pretty "high & dry." Location is between Springfield and Branson, MO--if I can ever get my house in Arizona sold so I can move!
Thanks for any help in clarifying these points. One day I hope to be able to put all this newfound knowledge to use when I buy my first tractor ever!!
   / Woody1934 #2
You might want to take a closer look at the Kubota web page. It states the L2800 and the L3400 both have 3 cyl. diesels and the L4400 has the 4 cyl. ORC means overrunning clutch.
   / Woody1934
Thanks for the reply. But, so you will know, the spec info I got came up as a PDF document from the Kubota web page. That page stated 4 cyl engines for the L2800 and L3400. Only when I went to another page to compare competitive models, did I find that the L2800 and L3400 had 3 cyl. engines. To me, this is a discrepancy in the way information is presented.
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
Portable Restroom (A54865)
Portable Restroom...
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
J and L Cargo Express Shadowmaster Enclosed Trailer (A55315)
J and L Cargo...
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
