Snow Equipment Owning/Operating Woods SB64S opinions
   / Woods SB64S opinions #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
Anyone got experience with Woods rear snowblower? SB64S good/bad points?
Need only info on this snowblower, everything else i know)))
   / Woods SB64S opinions #2
I have an old SB52 that has seen some use and abuse and it has served me well. My one desire would be for a larger diameter fan to help throw the snow further. I believe mine is considered 20 inch diameter measures 19.5 inches. I think newer models are now 21 inch. I use this on my Branson 2400H with approx 20 PTO HP.
   / Woods SB64S opinions #4
I have an SB54S new for this winter. Other than width, form what I understand it is the same. I am happy with it so far, it will chew through just about anything I've put it to so far and I have not broken any shear pins yet. The only thing is that the shoes could be wider and a bit longer. If you're dealing with a stone driveway or blowing off of grass the blower will dig in a bit if your not careful. I had a set of shoes made for me that I use when the ground is soft and then switch back to the OEM shoes when it frozen and have a good base for the blower to ride on.
Thanks, that’s what I expected to hear. I think sb64 got bigger fan diameter. Planning to use wheels rather than shoes
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2010 Case 660 Trencher (A50322)
2010 Case 660...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
