Woods RM-48 yoke
/ Woods RM-48 yoke #1
oliver28472
Veteran Member
Mt. Ulla, NC
Satoh S-470D, Mitubishi FD 1450D
Need a 18 spline metric yoke that slides on the tractor pto stub. I had one and gave it away. Anyone have one laying around? Most of these were for the reverse pto units.
/ Woods RM-48 yoke #2
How about I make your day?
Mitsubishi PTO Adapter
Quantity in Basket: none
Code: MitsuA
Price:$64.95
Shipping Weight: 3.10 pounds
Call Hoyle Tractor Parts at (940)592-0181
I can't seem to get the link to the page to copy correctly but maybe it will work, if not you can copy and paste it
Mitsubishi PTO Adapter: Yanmar Tractor Parts
Use this and you can just pick up a regular 6 spline yoke to go with it for your mower.
David from jax
/ Woods RM-48 yoke
Thanks for the reply but I have one of those. My problem is that something seems to be out of balance on my RM-48. First, I took the blades off. Still wobbling. Then I took the belt off, same problem so I think the trouble is in the small amount of slop with the adapter. I had one of the correct yokes and gave it away for shipping costs. I bought this used mower a little over a year ago. Popped the belt yesterday and put a new one on. Same problem. Looks like I'll have to pony up the bucks and buy a new yoke. Sure hope that will fix it. I have new u-joints but haven't put them in yet. Old ones feel tight. I should add that my adapter is not identical to that one.
/ Woods RM-48 yoke #4
do you have more than 1 speed PTO, maybe you are running it to fast. U joints in a shaft have to be timed with each other or they will viberate. they should point the same way. If the shaft was pulled apart maybe it was not put back the same way Larry
/ Woods RM-48 yoke
They are timed. My shaft is shaped rectangular so it cannot be out of time. The speed is correct also. The next step is to put in the new u-joints since I already have them. If that don't fix it I will have to buy the Woods yoke which is $85.00 plus.
2025 Grapple Hydraulic Mini Skid Steer Attachment (A61567)
2025 Grapple...
4022CFL (A59228)
4022CFL (A59228)
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2022 Ford F-150 Pickup Truck, VIN # 1FTMF1CB1NKE47600 (A61165)
2022 Ford F-150...
DRESSER GALION 712 TANDEM ROLLER (A62129)
DRESSER GALION 712...
832778 (A61166)
832778 (A61166)
