Woods RD990X Can't Get Blades Off to Sharpen! Best Method to Sharpen Them On the Mower?
   / Woods RD990X Can't Get Blades Off to Sharpen! Best Method to Sharpen Them On the Mower? #1
N750A
East Tennessee
Kubota MX5400
I have a Woods RD990X finishing mower that I bought new and have used for years to mow a grass airstrip. The blades are slightly dull - if I slow down, it still mows OK but the cut is a little ragged if I try to speed up. They haven't been removed in years, so when I recently tried to remove them for sharpening, it was very difficult to remove the bolts holding the retainers that allow the pins that the blades pivot on to come out. I finally got the bolts and retainers out but the pins would not drop out - they are apparently rusted in place. I tried everything - penetrant, tapping, heating, etc. but they simply won't come out!
My next plan was to simply remove each entire spindle assembly so I could put the pin in a hydraulic press and push them out. However, the pulley retainer on the top of the spindle seems to be rusted in place, too! I could get the large spindle nuts and the 3 smaller bolts retaining the pulley out easy enough, but you're supposed to run 2 of them back in through threaded holes to push the retainer collar off the pulley - all that accomplished was snapping the bolts off since the pulley retainer collar wouldn't budge.
The worst part is that there are 3 spindles and I see where this is going - lots of broken bolts!
So, as a last resort, I need to figure out some way to sharpen the blades on the mower. That's normally never a good option since you can't balance the blades. However, it looks to me it's either this or buy a new mower! I know I could get in there with one of those grinding stones with a nylon angle guide, Dremel stones, etc. but in my experience none of those work very well - I normally use an All-American Sharpener jig with an angle grinder and flap wheel and it works great - but you have to get the blade off the mower!
There's very limited access to the area above the blades since they're fairly close to the deck. I know I could draw a file down each blade and sharpen that way, but it'll take forever to remove much material. Since the blades aren't damaged at all and still cut fairly decent, I wondered if I could sharpen them with an angle grinder and flap wheel by lightly grinding the underside of the blade just enough to slightly sharpen it by reducing the radius of the rounded-off edge? I don't think it would take much to get them back to cutting a bit better/faster. The flap wheel would be many times faster than trying to sharpen the blade with a file!
John
   / Woods RD990X Can't Get Blades Off to Sharpen! Best Method to Sharpen Them On the Mower? #2
Did u heat the pin holder and not the pin? Did u place some blocking under the blades when trying to drive them out so as to get a "solid" hit on te pins?
Can u get a pipe wrench on the pins?
Yes - tried every combination of heating. You really can't get a solid hit on the pins - they have to be driven out from above, and the deck is so close that you can't swing a hammer directly down on the pin. There's not enough pin protruding to get a pipe wrench on them. The head of the pin on the bottom fits so tightly you can't get a gear puller on it, either.
John
   / Woods RD990X Can't Get Blades Off to Sharpen! Best Method to Sharpen Them On the Mower? #4
what did Woods recommend when you asked them?
   / Woods RD990X Can't Get Blades Off to Sharpen! Best Method to Sharpen Them On the Mower? #5
Now I know why I store all of my equipment inside.
Haven't asked Woods but guess it's worth a try to see if they have an idea I haven't already tried!
This mower was usually left on tractor and pulled into an open shed. I'm sure leaving grass on it and it getting wet from what blew in contributed to the rust. Definitely lesson-learned - I now blow everything off and recently sold my unused 5th wheel RV so I could park my brand-new Kubota MX5400 and the finishing mower inside an enclosed, dry building!
Still wondering if anyone got a little more life out of some blades by lightly sharpening the underside of the blade's edge?
   / Woods RD990X Can't Get Blades Off to Sharpen! Best Method to Sharpen Them On the Mower? #7
All my mowers with such connections have had an access cover from above in that area if the blades are spun to line up with it. Then can block underneath and drive out pins?
There is a hole in the deck that lines up with the retainer bolts, so an impact socket extension would fit. I suppose I could drill or burn another hole with a torch to align with the pin and try punching it out!
   / Woods RD990X Can't Get Blades Off to Sharpen! Best Method to Sharpen Them On the Mower? #9
You could try mounting a grinding blade up side down in an angle grinder. You may have to remove or rotate the shroud, but it would give you the clearance to grind the top of the blade.
   / Woods RD990X Can't Get Blades Off to Sharpen! Best Method to Sharpen Them On the Mower? #10
A good File might work better than you think
  • Good Post
Reactions: LD1
1991 Ford L8000 (A50120)
1991 Ford L8000...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
FAKE (A52472)
FAKE (A52472)
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
John Deere 3pt 7' Mower (A50121)
John Deere 3pt 7'...
