Woods grooming mower advice
   / Woods grooming mower advice #1
Youare
Platinum Member
Winchester, New Hampshire
Kubota L3000
I have the opportunity to purchase a used probably older Woods grooming mower, I hope fairly reasonable. I am wondering if anyone has any experience with this particular type mower.
I don't know the model number but it does NOT have a right angle drive gear box to transfer the PTO power to the belts. Instead it has a vee belt pulley about 18" in diameter that is connected to the PTO shaft which supplies power to the blade spindles through a couple of vee belts that make a 90 degree turn.
The deck appears to be around 60" wide and has only 2 gauge wheels in the rear. It is a side discharge model. The mower deck looks to be in decent shape and all the shafts turn I am sure the belts will need to be changed.
I am wondering if these belt driven mowers had issues because the newer ones do away with this type of belt drive and use a gear box. Any advice would be appreciated.
Thanks,
Randy
Rock wood travel trailer (A51694)
Rock wood travel...
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
New/Unused Agrotk Tire Changer (A51573)
New/Unused Agrotk...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2020 CATERPILLAR 279D3 SKID STEER (A51246)
2020 CATERPILLAR...
2019 JOHN DEERE 8245R LOT NUMBER 187 (A53084)
2019 JOHN DEERE...
