Rotary Cutter Woods Brushbull 48 too heavy?
   / Woods Brushbull 48 too heavy? #1
RaptorRidge
Kubota/BX2380
I have a Kubota BX23480 with FEL and want to purchase brush hog. My dealer recommends a 48" LandPride. He also sells Woods but says the Woods Brushbull48 is too heavy for this small tractor. However, I have found a Brushbull48 on Craigslist that is mush cheaper than buying a new LandPride from the dealer. What is your opinion...is the Woods 48 too heavy?
   / Woods Brushbull 48 too heavy? #2
The Land Pride is lighter but only by 80 pounds or so. It will be a load for the BX2380 but I would not be afraid to use woods.
   / Woods Brushbull 48 too heavy? #3
:welcome: to TBN.
What your mowing conditions...rough ground,slopes,what are cutting could be factor,
   / Woods Brushbull 48 too heavy? #4
I question if the 48" Woods will properly fit the Category 1 Three Point Hitch on a Kubota BX. If it fits reasonably well you may be short of mower adjustment increments.
I do not know for certain but I have a doubt.
Call Wood's customer service to check on BX fit.
The dimensions of a Cat 1 TPH are standard across brands.
The lowest drop point is not. The highest lift point is not. The range between the two points is not.
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A52748)
New Lewis Brothers...
