Ken,
I just took a look at the specs for the L4330HSTC with the LA853 loader. Heavy tractor compared to the 2900.
Curb weight is 3860#, Loader is 1000# (estimate) loaded tires another #1000 (estimate), Backhoe is #1300 +/-.
My 2900 on the otherhand is:
Curb weight #2810, Loader is #600 unloded tires and backhoe is #1300.
The 4330HSTC as best I can tell is about #5800 less Backhoe,
The 2900 is about #3400 less backhoe. I may have the tractor jumping around alot if I am not careful.
As for the sub-frame part number, the cab versions require different sub-frames. I have had a terrible time getting our local woods/kubota dealerships to tell me the infomation I need since I am not buying anything. The local kubota/Woods dealership said I could not mount that hoe on a
L2900. In speaking with Woods, They said it could be done and they designed a subframe for that application. Part #1001199
As for the BH9000/BH90-X differences. I have been told they fit on the same sub-frames. I would like to confirm that the information I have been given is correct.
Backhoe Sub-Frame Mounting Kits Operator's Manuals
The above link shows the BH9000 fits with the #1007399 sub-frame.
If this is true, and I buy the 3130/3430 sub-frame and may no modifications to the parts, just make additional brackets for my tractor to create the same mounting points. The BH/PTO pump/sub-frame could be sold as a complete kit if I am no longer using it. The market for that kit is much higher than the
L2900 version.
Any thoughts on the XX40 models? What subframes will they use?
Thanks so much for you help.
JR (Design)
