Woods Batwing cutter cylinder leak
   / Woods Batwing cutter cylinder leak #1
WeBBeefmasters
JD 5425
Hello, I have a Woods batwing and I replaced the hose to one of the cylinders that lifts the wings. So now I have fluid leaking from the Vent Plug when I lift or lower the wing. The plug is the type that has the hole in the side of the bolt head and steel wool looking stuff with a mesh screen on the inside. Any ideas what would cause this? Air in the line? The set-up is both wing lines go to a T at that plugs into the tractor. This side leaking is the first side to lift. Thanks for any help you can provide!
Thanks! I'll start pricing cylinders.
   / Woods Batwing cutter cylinder leak #4
I would make a few phone calls and check on a rebuild price before I would by the new cylinder. It might be cheaper to buy a new one but you never know.
You're right. OEM cylinder looks to be expensive. I'll see if an after-market is cheaper. A seal kit looks to be less than $100. I've never rebuilt a cylinder but I'm sure there is a youtube video on it.
   / Woods Batwing cutter cylinder leak #6
Before you buy the seal kit you might want to take the cylinder apart and check the condition of the walls and tube. Sometimes you can get condensation inside a cylinder and that can cause rust or corrosion that tears the seal. If that's the case, a new seal kit won't solve the problem without cleaning up the cylinder. If you store the mower with the wings down, this would especially be a possibility because there is a large volume of air exposed to temperature changes. If you store it with the wings up it's still a possible problem, but less likely.
BROWN BDH-600 LOT NUMBER 174 (A53084)
BROWN BDH-600 LOT...
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
Year: 2015 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 90,702 Plate: Body (A51694)
Year: 2015 Make...
