Woods backhoe for NH
   / Woods backhoe for NH #1
wayne1083
Southern Indiana
NH TC33D
Guys I have a 2003 TC33D with a 72"mmm and 7308FEL. The best cutting machine I have ever seen. One of the reasons I held off on the backhoe was of the non-compatibility of it and the MMM. I understand that Woods makes a backhoe with a 4pt hitch and subframe that works with this set-up. It this true and does anyone have any experience with this equipment? What are your thoughts...Thanks a bunch for your help.
   / Woods backhoe for NH #2
I understand the same thing, but have no first hand experince. The best thing to do is check with your woods dealer. They would have the most recent info. What I understand is woods is always coming out with new mounts, and dealers should be the best way to find out if they have one to fit your needs.
   / Woods backhoe for NH #3
I have the new Woods 4 point hitch subframe with a Woods BH7500 backhoe installed on my TC33D (along with a Woods model 1012 loader). Here's a quote from the subframe installation manual:
</font><font color="blue" class="small">( Only use 1013460 4-Point Sub-Frame Mounting Kit for mounting Woods BH6500/7500 backhoe on New Holland® TC29DA and TC33DA tractors, equipped with Woods 1009 and 1012 loaders or New Holland 14LA loader.)</font>
Note I have the older TC33D, not the TC33DA, but after some checking with Woods, they said it would fit the 33D as well. The subframe was installed by my dealer. There were no problems with the installation other than needing to relocate the quick disconnects for one of my two rear hydraulic remotes.
I love the set up, and it works great! Easy on and off, and not as much ground clearance lost under the tractor as with some other subframes I've seen.
I can't guarantee it will work with the 7308 loader, but knowing that it works with the Woods 1012 loader on a TC33D, it should be a simple question for your dealer or the Woods Tech rep to see if it will work with your 7308 loader.
I don't have a mid-mount mower, but here's another quote from the subframe installation manual:
</font><font color="blue" class="small">( This mount can be installed on tractors equipped with a New Holland mid-mount mower. )</font>
Hope some of this helps.
John Mc
Chevrolet C8500 Flat Bed with a Moffet Kit (A53472)
Chevrolet C8500...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2015 Ram 4500 Utility Truck, VIN # 3C7WRKAJ9FG707673 (A51572)
2015 Ram 4500...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
