Woods Backhoe: BH75 on CK20
   / Woods Backhoe: BH75 on CK20 #1
Slackdaddy
Land of the Free
Kioti CK20HST
I have a CK20HS and was set to buy a woods BH-70X backhoe, but they are no longer available.
I am looking at the Woods BH75 hoe.
Any have one on a CK20 ?
Thanks,
Slack
   / Woods Backhoe: BH75 on CK20 #3
Normally the KB2465 is used on the CK20. The BH75 is similar to the KB2475. By your spec sheet, the Woods is lighter than the Kioti but has more digging force. My KB2375 can drag my CK30hst around depending on what I'm digging in. I think you'll be fine as far as bh weight. The extra reach will be nice.
Vic,
I believe the Kioti specs include the frame, the woods is just the BH but not the tractor specific frame.
Talked to Woods tech today.
The older Woods BH-70X weighed #832
The newer BH75 weighs #850
Plus CK20 frame kit - #270
Both require 4-6 GPM
So if people where happy with the weight and fit of the BH-70X on their CK20, the BH75 should be OK?
Still both weigh more than the Kioti KB2475 (#1052), why did no one use the KB2475 on the CK20 ?
Slack
   / Woods Backhoe: BH75 on CK20 #6
I used bh70x on my kubota b2320, and then for a little while on my ck27 before I went up to bh80x. Not only your machine will handle it fine, I think that the woods set up is easier to put on or remove.... Plus, the feature I really liked is that you can leave your 3pt arms on the tractor.
   / Woods Backhoe: BH75 on CK20 #7
I don't think the woods is easier to mount than the Kioti backhoe, I looked at them both and went with the Kioti for that reason and the fact it was less expensive. Of course this is on a CK30, but I doubt there would be much difference.
With the Kioti you can leave the 3pt as well...
One of the many reasons I didn't buy a kubota.
Wood Fence Posts (A50121)
Wood Fence Posts...
2018 Kubota R530 (A50120)
2018 Kubota R530...
CFG Industrial MX20R (A50121)
CFG Industrial...
1999 Lull 1044C-54 Series II 10,000lbs 4x4 Rough Terrain Telehandler (A50322)
1999 Lull 1044C-54...
2003 Lexus LS 430 Sedan (A50324)
2003 Lexus LS 430...
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
