Woods 90BH-X on a JD990
   / Woods 90BH-X on a JD990 #1
nitelite2
Western Mass
I have been out on the forum as a visitor "soaking up" knowlege from all of you for some time which has been great and I now need some help regarding purchasing a backhoe for my 990. This is the first time I have posted. I know that JD makes the 8B for my tractor. It seems that the Woods 80BH-X would be a good fit for it also. Is the 90BH-X too much hoe for the tractor and if it is should I go with the 80BH-X instead of the 8B?
thanks for helping me spend my money
nitelite
   / Woods 90BH-X on a JD990 #2
I'm not real familiar with the JD990. I think 40hp is about the minimum you'd want with a BH90x. The 80x would be the better match if it is smaller. It has all the features of the 90x with just a bit less reach.
I have a 90x on my Kioti DK40se and it works fine.
   / Woods 90BH-X on a JD990 #3
Just my 2 cents. The lift capacity of the JD990 is 1537lbs (According to tractordata). That is if you're going to use a 3pt mount.. The do make a frame for the 970 but I couldn't find the 990 any where. They make a 9000 series frame for the 970, so I'm guessing if you use a subframe mount you'd be ok. I'm one of the those that I try and choose implements that are smaller than the tractor. I'd rather have the implement break then the tractor.
Wedge
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2004 INTERNATIONAL DURASTAR 4300 (A50854)
2004 INTERNATIONAL...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
