woods 6250 PTO/clutch switch
   / woods 6250 PTO/clutch switch #1
docm
N GA, south of ATL
Kubota L2500DT 4WD
my mow-n-machine 6250 stops cutting and starts again. belts are good. I'll be cutting and the pto will disengage, I stop open the pivot arms and it may start cutting or I'll disengage the PTO switch & re-engage the switch & starts cutting again or sometimes I'll just stop and go again & starts cutting. Not sure how to check pto switch or electric clutch
   / woods 6250 PTO/clutch switch #2
I've had similar experiences with my 99 model Grasshopper. The first time it was caused by the pto switch. The next time it was the plug to the electric clutch. Exposure to dirt and corrosion over time causes the failure. Pretty easy to trouble shoot even without a schematic. I would do a visual inspection of the connections at both the switch and clutch. If those look good, check for continuity of the clutch and for voltage to the clutch. Check continuity with the clutch disconnected. The mower doesn't have to be running to check for voltage. With the clutch plugged in and the pto switch "on", you should hear the clutch click when you switch the ignition switch "on". Of course the clutch could be slipping, which will likely require replacement. Some of the older clutches had three studs with nuts that are adjustable.
Good luck.
Jim
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55301)
Case Wheels for...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
