Hi,
I have a MF GC2410 and a Woods 5000 chipper that stalls the engine upon PTO engagement. When I purchased the tractor the gentlemen said he thought the chipper might need new belts because it squealed. Upon testing it did, in fact, squeal like a stuck pig. So, I purchased a couple belts and tore into it. I found the tensioner spring broken and the belts installed were narrower than the belts listed in the manual. I installed the new belts, a new tensioner spring, greased the fittings and turned the large sheave by hand which turned the cutters inside....it did take some force to get it moving. I reassembled and connected it to the tractor.
When I engage the rear PTO it just barely starts to turn the chipper and then the tractor stalls out. I disconnected the chipper and started the rear PTO and it turns fine unloaded, so it's not some sort of safety switch. And, before swapping the belts and adding the spring the PTO turned the large sheave on the chipper - although - maybe not the cutters due to the lack of tensioner. I reached out to Woods to ask about the belt width and they did confirm the ones I purchased were the correct ones.
I would appreciate any ideas.
Thanks!
Thanks!
