Woods 3150 Mow n machine
   / Woods 3150 Mow n machine #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
Does anyone have any idea on the brand of HST's used on a woods 3150 mow n machine. Neighbor has one were the right side drive quit working and I can't find any numbers on it anywhere. We have not removed the drive from the frame since I suspect the repairs may cost more than the machine is worth.
TIA
Decided to pull the drive out and after some serious degreasing found some numbers that I believe are for and old Eaton unit.
770 009 051090CCW I believe this is an obsolete 770 series light duty transaxle that has been semi replaced by the 771 series. The 771 series require different or modified mounting holes and different input shaft diameter from what I can find on the net.
Any Eaton experts that can confirm this?
2022 CATERPILLAR 289D3 SKID STEER (A50458)
2022 CATERPILLAR...
360 Yield (A47164)
360 Yield (A47164)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
2003 Sterling L7500 Day Cab Truck Tractor (A46683)
2003 Sterling...
2023 FORD TRANSIT 250 VAN (A45679)
2023 FORD TRANSIT...
Ryobi Sliding Compound Miter Saw (A48837)
Ryobi Sliding...
