Woodmaxx WM-8H
   / Woodmaxx WM-8H #2
I'm looking to add the WM-8H to my Kubota B3350. I have a post on a comparason between that and the Woodland Mills WC68, wrongly titled WC86 - because I'm dyslexic. Hope that helps.
   / Woodmaxx WM-8H #3
It weights almost 1000 lbs...are you even going to be able to lift it with a GC?
   / Woodmaxx WM-8H #4
WM-8H recommends a minimum of 19HP HP to run their chipper. Kubota specs say the 3-point hitch lift capacity at 24" is 1,676lbs. So unless some one is lying it should work!
I have a FEL, as well that should help balance things out.
   / Woodmaxx WM-8H #5
At 19 HP PTO, you will not be chipping 8" hardwood with the WM-8H, per the Woodmaxx web site. It states 50 HP PTO is needed to run at the max rating.
   / Woodmaxx WM-8H #6
Sorry, my reply was meant for the original poster, who has a Massey Ferguson GC1710, with a rated lift capacity just shy of 1200lbs at the pins...I suspect the chipper is 4-5 feet long, so that 1000 lbs is distributed quite far behind the pins.
You're B3350 is a very different tractor...you'll be fine. The OP, maybe not so much...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
2013 Dodge Durango Express SUV (A48082)
2013 Dodge Durango...
UNUSED Portable Double Bathroom (A50860)
UNUSED Portable...
Excavator Bucket (A50860)
Excavator Bucket...
UNUSED Clear Multi-Wall Polycarbonate Panels (A50860)
UNUSED Clear...
