Backhoe Woodmaxx vs Wallenstein backhoe
/ Woodmaxx vs Wallenstein backhoe #1
asic ace
Micco, FL
IMT, Kubota
I'm looking for a PTO backhoe for my Kubota L3400.
I've been eying a Wallenstein GX600 that apparently was bought in 2008 and never hooked up. It's been sitting outside since then.
The seller recently hooked it up and said it works fine. It requires hydraulic remotes so I'd need to use my bucket tilt connections
and get longer hoses and different connectors. The seller is about 2-1/2 to 3 hours away, so I could spend a day to check it
out / buy it. He's asking $3,000. In my experience, things that are used regularly are better off than things that have been sitting
idle for years, especially outside. The seller said the pistons were all retracted, so no pitting on the shafts.
Then I read about the Woodmaxx WM-6600. It's $4250, shipped, and has a PTO hydraulic pump, which I'd prefer. I get the
impression that Woodmaxx is new to backhoes, so I'm wondering if anyone has any experience with them?
How are their other products, do they have a good reputation?
The GX600 can also be used with a PTO hydraulic pump (PTO70), which I haven't been able to track down yet.
That may be an option, but acquiring a PTO pump plus losing a day of my time makes the $1250 difference
balance out.
So I'm looking for opinions on either brand.
Has anyone used a Wallenstein GX600 or a Woodmaxx on a Kubota L3400? Or on anything?
One other question, if I use my bucket tilt connections, do I just detach both hoses and use those or do I need to use
one side and tap into the return line for the other? That would be a deal-breaker as I don't want to change the plumbing
on my Kubota.
My use would be very light, mainly digging in Florida sand but I have some areas with clay, but nothing like the clay I
had in California. Also, this isn't urgent. There are things I could use it on tomorrow but they can also wait until next year.
-- Ace
/ Woodmaxx vs Wallenstein backhoe #2
I could have sworn that someone on here has gotten a woodmaxx backhoe. I tried a search and couldn't find it. If their backhoe is the same quality as their chipper I wouldn't be to afraid.
Wedge
Well, I finally located a PTO70 Wallenstein pump kit for $1170. Wow.
I guess I could use a cheaper pump kit but this puts the prices closer together.
I just called Woodmaxx and ran into a menu system with a choice of "1" and nothing else.
The person I spoke with said these are made in China but they are very proud of them.
The WM-6600 is a new product but the larger WM-7600 has been out for about a year and a half.
He pointed out that a PTO pump guarantees proper flow and doesn't mix the tractor and implement oils,
which was something I was worried about.
For my light use, the Woodmaxx looks ok. I'm not too keen on being one of the first buyers, though.
/ Woodmaxx vs Wallenstein backhoe #8
That's interesting - I've been watching their website for quite some time and I never even saw a backhoe on there until July of this year. After looking closer at the backhoe it looks surprisingly similar to these units sold by The Tractor Man: The Tractor Man, Inc. perhaps with a few modifications.
/ Woodmaxx vs Wallenstein backhoe #9
I was looking at Alibaba.com which is a Chinese site that sell everything including all kinds of backhoes costing from $1250. up to $1800. There is no minimum order but I am a little more than concern ordering from China.
/ Woodmaxx vs Wallenstein backhoe #11
I use a gx620 hoe an they work fine, in your case i would buy the gx600 over the Woodmaxx.:)
Mguitas what are you using for a subframe mount? I have a 1428v and am shopping used backhoe options and would prefer to
subframe mount whatever I end up buying
/ Woodmaxx vs Wallenstein backhoe #12
I see this post is older and wondering if you still like the backhoe and if you had any issues with it.dealer here is reccommending it as he cant find me a kioti backhoe for a month and a half?
/ Woodmaxx vs Wallenstein backhoe #13
I do like these backhoes, just working the hoe the other day. On this 1423 massey, i have a subframe mount with it. Today wallenstein make alot of four point hitches for many makes an models. I just seen a koiti with a backhoe a month ago at the fair. An to my supprise they have subframe mounts for there hoes, but not four point hitches still , most models do today. I wonder why. For this massey they only had a subframe for it , an i wish it had a 4 point hitch.
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
2009 Toyota Camry Hybrid Sedan (A61574)
2009 Toyota Camry...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
