Overtaxed
New Member
- Joined
- Aug 2, 2016
- Messages
- 371
- Location
- Gaffney, SC
- Tractor
- Kioti NX6010, JD 2720 w/46BH, Honda Pioneer 1000
Had my 8M for about 3 years now and I'm having a problem with it where the clutch is jumping out before the tractor really gets loaded. Took it apart today and the two plates that come together are rounded, that's why it's popping out, as the torque rises, it'll ride up and over. I found the part to replace it; but what I'm wondering, how is this thing supposed to be adjusted? I can change it from "fully engaged" (where it won't pop) to loosely engaged, but it seems that anything other than "full engagement" is going to lead to the same issue, the edges of the clutch getting worn down when it pops over.
So, how is this thing supposed to work? Is "clutch" a misnomer here, it's really an "engage/disengage" (with no slipping allowed/expected at all)? If so, I'll just adjust the new one to "full engage" and be done with it. The problem with that, a few times I have chucked something in there that really did jam it, and then it's a mad rush to the PTO switch on the tractor to stop it spinning before the belt burns up.
Any suggestions? Oh, and more confusing, there are adjustments available on engage the clutch other than fully. Nothing showing in the manual about how to adjust, just that it's adjustable.
(WM-8M) Clutch assembly includes part (WM8M-7-5,7)
